Cadillac & LaSalle Club Forums => General Discussion => Topic started by: My57CDV on September 22, 2018, 01:51:05 AM
Title: 1957 CDV Brake Fill Tube-Fluid Level
Post by: My57CDV on September 22, 2018, 01:51:05 AM
I believe the Brake Fluid Fill port is the vertical tube on the left side of the power brake unit on the fire wall.
Question:
I removed the Top Cover (with the square nut) - where should the Brake Fluid Level be at?
I did not see any lines nor marks on / in the Tube to indicate fluid level. I have read the Service Manual and not found any direction for Fluid Level.
Experienced input Requested Please!
Mark Anderson
Title: Re: 1957 CDV Brake Fill Tube-Fluid Level
Post by: gary griffin on September 22, 2018, 04:20:48 PM
I fill mine up to about 1/4 inch from the top.
Post by: chrisntam on September 22, 2018, 04:49:45 PM
dot 3 fluid ok to use?
Post by: Mike Josephic CLC #3877 on September 22, 2018, 07:46:57 PM
DOT 3 is fine.  Do you know what's in your car
right now?  It's best to not mix fluid types.  You
most likely have DOT 3 as that has been the
standard for many years.
Post by: My57CDV on September 22, 2018, 10:35:16 PM
Thanks! everyone for the Reads and Replies ...
I found the Specific Direction in the 1957 Shop Manual ...
Page 8-10
  (9)   7.  Refill reservoir only with clean Delco Super No. 11 Brake Fluid to within 3/4" of top.
I am using DOT 3, Non Synthetic.
Mark A.
