Checked 429’s oil after solving antifreeze problem, the fresh oil (200 miles) stinks like gasoline.
Advise please.
Pat
Fuel pump diaphragm is leaking?
Lucas F. CLC #15674
1963 Series 62 convertible
First place to check is the fuel pump - the diaphragm may be bad and allowing fuel to pass into the engine. Next will be carb problems.
Requires a new fuel pump?
pat
