1938 LASALLE
Started by DAVID E, January 29, 2017, 01:37:47 PM
Steve Passmore
David, we are talking about the back lifter cover rather than the back of the front lifter cover. Someone in the past deicide to have the return pipe of your oil filter deposit back in through the lifer cover which is not usually the way its done, but they did it. Its not a problem but as I said before, don't confuse that with the crankcase ventilation system.  Tom is saying that on his cars he has a fitting in the rear lifter cover for the air cleaner pipe. I did not on my Cadillac, it came from the ''T' fitting.   If you do not have a fitting in the back cover you can either make one or connect it to the 'T' fitting in the manifold.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
DAVID E
Thank you 49er! Those help a lot, You also help me with a post I had a few months ago about two cables that came from the firewall, I can see the one connected to the carburetor. I am not sure about the other one yet. I just got to find where that tube goes that you fabricated on your car
Tom Beaver
David,  I took a couple of pictures of my spare 38 engine which show the two vent pipes installed on the engine.  On the rear vent pipe I added a PCV valve, just to be on the safe side, and shortened the bottom end of the tube accordingly.
Tom Beaver
DAVID E
Thanks, Tom, and 49er!
I am going to remove that oil filter canister and installed that tube for the air filter assembly. so that will take care of that. The pictures help tremendously
DAVID E
also is there supposed to be oil in the air filter container?
Tom Beaver
David,  The oil filters from the factory were all oil bath.  In my experience they are both a mess and a royal pain to service.  I would recommend replacing the entire oil bath assembly with a modern paper element (Fram # CA 148). The only original parts still used are the outer oil bath housing and the top (that connects to the carburetor).  It does not alter anything and you could always put the oil bath assembly back in if you wanted to show the car.
Tom Beaver
Brad Ipsen CLC #737
I'm late responding on this but on the V-16 the orifice is in the fitting.  It is also a tee fitting with the unused port plugged.  Since the V-16 had dual carbs the port on the bottom of each intake manifold (under the carb) is brought to a central location and then after connecting with a conventional tee is brought to the fitting with the 0.090 hole which in turn is screwed into a tower on the valley cover.  Quite different from the V-8 but functionally identical.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Steve Passmore
Even more confusing then Brad because if the orifice is in the fitting I definitely didn't miss a small opening into the cast manifold, that was definitely never drilled out.     I may had had something in the fitting I don't recall. Be interesting to see what's on my latest 38 but I'm unlikely to remove it just to look ;D
Steve
Present
1941 62 coupe
Previous
1936 70 Sport coupe
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
