A5 Compressor question
Started by Cadillac Jack 82, April 02, 2021, 01:23:11 AM
Cadillac Jack 82
So my AC works but the compressor seems hot to the touch.  Is this normal or a sign of it going bad?  It doesnt make noise and seems to work appropriately.
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
J. Gomez
Quote from: 55 CDV Fan 82 on April 02, 2021, 01:23:11 AM
Tim,
First question is; do you have the correct oil viscosity added to the compressor, and second have you added the correct amount?
These compressors with R12 required the mineral oil viscosity of 525 with about 9oz added to a new drained setup.
J. Gomez
CLC #23082
Cadman-iac
Tim,
  Most of the compressor will be hot to the touch, that's normal as it's compressing the refrigerant, and heat is the result. The only place that is not hot is typically right at the low side hose connection.
Now if it's making an excessive amount of noise, and the paint is baking off, those would be signs of a problem.
Rick
CLC# 32373
Cadillac Jack 82
Rick its quiet but just hot to the touch except for one of the lines which is ice cold.  Guess its working? Lol.  I'm not familiar with these old systems.  It kept me cool today and its 96 degrees.
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Cadman-iac
Sounds like it's working just fine then.
CLC# 32373
