429s oil smells like gasoline
Started by Pat, August 11, 2006, 09:55:18 AM
Pat
Checked 429’s oil after solving antifreeze problem, the fresh oil (200 miles) stinks like gasoline.
Advise please.
Pat
Lucas F. CLC #15674
Fuel pump diaphragm is leaking?
Lucas F. CLC #15674
1963 Series 62 convertible
Tod - North TX CLC
First place to check is the fuel pump - the diaphragm may be bad and allowing fuel to pass into the engine.  Next will be carb problems.
Pat
Requires a new fuel pump?
pat
