I just purchased a 1960 Eldorado Biarritz with 60,000 miles on it, from the original owner. The car has been stored since 1977, with the frame supported by jack stands, so the weight was kept off of the suspension. The car is amazingly original, original paint, extremely nice red leather bucket seats, and original top. I would like to do an article for the self starter about the man and the two cars I just bought from him.The air ride on the 60...I need to know some do's and don'ts on working on the system. It will take and hold pressure and lift the car if you put air into it from the valve on the air tank under the hood, but it bleeds out over night. I don't know if the compressor will work, because I have not tried to start the car yet, although it turns over very freely.I have a frame contact lift (not a drive-on), so I can get the car on the lift to start looking for the leak, if there is one.If anyone reading this has some tips or suggestions, let me know.This car was purchased new in 1960, driven only as a pleasure car on nice weekends, and stored every winter. In 1977, the owner purchased a new 1977 Biarritz, and also drove that sparingly, as it only has 45,000 miles on it, and is basically like new. He is older now, and no longer driving, and I bought both cars and brought them home to my garage. The 77 was driven home, the 60 on a flatbed. I have to drain everything, drop the tank, pull the wheels, and go over everything before I try to start the car.The paint and chrome are both oxidized, but the spots I compounded so far are looking very nice. The interior will be mint with a nice cleaning and treatment of the leather.I will update with some photos and info as time permits, and will start reading the shop manual tonight, but as far as the air ride, please let me know what to look for, how the controls work, etc.Thanks,Brian
Hi BrianThat sure is a GREAT car, my favourite colour combination too.I have a 59 Biarritz with air ride.Most of the comments so far, have been very sensible, and should cover everything you need to know.The only thing I would like to point out is, try not to let the car bleed right down, without the car being supported, either by blocks above the diff and front A arms, or supports under the chassis.When the car drops right down, the driveshaft support can be strained ( rubber part), leading to premature failing of this part.I have had no problems with my cars air ride, with the lever pulled out, and car fully raised, it will drop to about halfway down, in a day and half.With the air lift lever in and car at normal height, car has stayed up happily for a week, without the engine running.I must point out I always drain the air tank and let the car drop on blocks when I am not using it.I modified a gas ( not gasoline, but gas), tap to scew into the original thread on the bottom, of the air ride tank, and on the end of the tap I threaded a compresser line fitting.This means I just have to reach under the tank and open the tap and tank is emty in about 15 seconds. Before I start the car ( it is not a daily driver), I just hook up a compresser line and pump the car up, saves running the engine for about a quarter hour to pump up system.I would advise you to keep with the air ride, anyone with any practical car knowledge can easily keep the system going.Air ride cars sit GREAT, lower at the back .Air ride cars FLOAT down the road.And the great thing is, you can LIFT the car up, when you come to steep drives, etc, you will be amazed how easy it is to drive the car places that a spring car will be scaping on the ground.Hope this helps, for more technical questions, you can e mail me direct.Love your car, great find.Richard
