The engine block casting number is 1485200The head casting numbers are 1497902
This may not be bad, but damn frustrating when you go out parts hunting.
From 71 on the engines had the 61 (62, etc) codes with Q (Detroit) or E (Linden NJ). And yes Michael, in my 68 shop manual also the famous "where-you-can-find-the-VIN-number-on-the-block" line is mentioned but the only numbers I can find are the engine block casting number and the mysterious serial number.
"It's not a 75 or a 76 engine because they are electronic fuel injected (E.F.I.) and mine isn't. See http://www.butlers-a1.com/caddim.htm"Wrong answer. These engines are both...carbureted and TBI injected. EFI wasn't introduced until 1977 on the 425 in the Fleetwood
Okay, I took a good zoom-in look on the 3.2 MB picture and I can see indeed a difference between the first "0" (more square) and the second "0" (more oval). The first is probably a Q (with the dash) and the second a zero. See zoom-in pictures enclosed.Does this help, that the serial number stamped in (not casted as I stated before) on the engine is 66Q192082?Best regards,Geert-Jan
Here is the picture of a later block. The yellow is the block part number. The red is where the serial number should be. As you can see the block must be very clean to even get a hint of the number. I rubbed that one with my finger and still cannot see it.Stampie
You wstate in your post that the number "66Q192082" is on the engine. Where?? I(f you can get to it, I suggest removing more paint, and posting the number(s) again. Good luck,JIM
