Man, I just can't keep up with shop prices. $120 an hour?? That's why I'll always drive a 60s-early 70s car and truck. I can do most jobs at home. Once it came to opening the hood and not being able to detect an engine without an X-ray machine, the car is too new for me. I prefer when it's hard to see anything EXCEPT the engine.
Every story I have heard of a 4100,4.5, or 4.9 if the hot light came on engine was toast, especially when there was more driving involved. Warm light has a chance if it was not driven further. Because of the labor involved I would only consider a used motor if I knew and trusted the history of it. For a rebuild make sure you read all their warranty info especially how it deals with labor if there is a problem. There are a couple of yards around here that do cover labor on used motors for 30-90 days but I think those motors are too old now so they tend to end up in the U pull yards.
Hey all,Thank you very much for all of the input!First, since a few of you asked, here's the scenario of the entire incident- #1 - The message center told her the engine was 'warm' and she checked the temp, it was 225 She turned the heat on high and drove it to the inept mechanic. He said it was the t-stat, he replaced it and some coolant. Supposedly road tested it, said it was ok. She picked it up. #2 - She picked it up, goes just over a mile and gets the 'engine hot' message, it's reading 260. The overflow tank bubbles over, turning the heat on doesn't help. She pulled over, raised the hood and called the inept mechanic and THEN me. I go pick her up, the car has cooled off. I drive it back to inept mechanic. He states "oh, there must be a blockage" We leave it, it's ready in a few days. "It was the sensors that were bad." Okie dokie........... #3 - She picks it up, he tells her it's been road tested and all set to go. She makes it about 5 miles and she gets the same 'engine hot' message and the temp is 260 again. She pulls over, calls me, I have it towed to MY mechanic and he tests it. There are exhaust gasses or something in the coolant, he pronounces the engine 'toast'.Tassie - The inept mechanic claims the cracked(?) head/block was the cause of the overheating initially and that he did nothing wrong. He said doing a block test to check for circulation would have been one of his next tests. I have no way to prove he did the damage. Even my regular mechanic said there's no way even HE can prove it.Rusty - Thanks for the info! I'm glad you shared the differences between years/motors. It wasn't MY mechanic, but a 'neighborhood' guy my daughters boss recommended. TJH - Unfortunately I don't know anyone that has the capability and tools to try and do this. My brother says he can do it, but he's on the wrong side of the US. The labor was $1525 ($95/hour) plus we already knew it needed motor and transmission mounts which I think was another $400 (parts & labor). Thankfully the transmission is fine, never a problem with it. John Morris - As mentioned above to TJH, my mechanic charges $95/hour and does excellent work. I have used him for more than 12 years and he has always been up front, fair and knows his stuff. Is he the cheapest? Not by a long shot, but I trust him and he's always done right by me and my family. He breaks repairs down into 'do it at some point as money allows', 'you'll need to get this done in X amount of time before it get's worse or is a safety issue' and 'DO IT NOW!' LOL I already know that replacing the motor with the Jasper engine isn't fiscally the best idea, but I also can't let the car go and junk it or part it out. Here are some options I've been given - Keep my eye out for a low mileage car that possibly has body damage or something, but that the motor is good. Possibly find a car that someone else has already replaced the motor with a new one. K - W Permanent Metallic Block Seal. This comes highly recommended by quite a few people. For $20, it's worth a shot! It's not like I have to worry about doing MORE damage than has already been done!! LOL Thanks again to everyone for your input! I will keep my eyes on the board for any other comments or suggestions! I'll also be sure to let you know what eventually happens!Have a great Super Bowl Weekend!!Marc
