64 Eldorado Convertible Top and Power Windows.
Started by Johnny F #662, January 27, 2008, 07:18:40 PM
Johnny F #662
A fellow CLC member, took his car out today to attend a AACA show, and his top and power windows stopped working and he suspects it is caused by a bad circuit breaker.  He now has a problem finding where the circuit breaker is, so he can change it.  Can anyone tell him where and how to change the circuit breaker?  Thanks in advance.
Warren Rauch
  You probably don't have a horn as well as the other problems.  The 40 amp curcuit braker that feeds them all is in the fuse block near the driver's feet (" on the lower flange of the instrument panel to the left of the steering column'). It is a little metal thing that clips into the fuse block like a fuse. It is in the position marked" horn".Warren
