I dont know anything about a 57 but in general I would assume that that vintage would only have one wire to the sending unit so grounds become important. Perhaps when you had the tank out you disturbed the ground connection? Or by installing new hangars or insulators you insulated the thing too good? First step would be to unhook the wire and see which way the gauge goes. It should either go all the way up or down. Next ground the wire and it should go all the way the opposite way. This will confirm that the gauge works and the wire is good. If full is the state it goes to when unhooked I would go after the ground issue. It could be something like the gasket in the sending unit is keeping the unit from grounding to the tank. In some cases I have seen people clamp a ground wire around the outlet line with a hose clamp. Not pretty but it works.
Here's a good link for ya, it's for a Chevy but the principals are the same. http://www.classicchevy.com/assets/pdf/29-92.pdf? Lou
I had a gas guage do that. I took the sending unit out of the tank, a copper strap had seperated. We brazed it back on, reinstalled the unit and WHALLA!! Gas guage fixed.
Quote from: John Morris #23947 on February 01, 2008, 10:50:26 AMI had a gas guage do that. I took the sending unit out of the tank, a copper strap had seperated. We brazed it back on, reinstalled the unit and WHALLA!! Gas guage fixed.This seems to be a relatively common occurrence, I have seen this same type of failure in 2 '66 Cadillacs.
Does that copper strap flex when the float goes up and down? If it does a better fix might be to solder a small braided strap in it’s place. Just a thought. Glen
