Cleaner to remove ground-in GUM on shale grey 2004 leather seats?
Started by Matt CLC#18621, February 08, 2008, 10:09:28 AM
Matt CLC#18621
Simple Green indicates not to use on leather and Spray Nine was noncommittal?
Matt
homeonprunehill
Quote from: Matt CLC#18621 on February 08, 2008, 10:09:28 AM
Matt
Matt, Try an "ICE-CUBE" wrapped in a wash-cloth, Freeze the gum and it should pop right-off.  Just make sure that the gum is frozen, you can tell when its frozen by your hand being frozen. Put some leather treatment on the spot after removing the gum.
G'Luck,JIM
John Morris #23947
71 Olds 98 LS, 66 Fairlane 500 XL Convertible, 55 Packard Clipper Super, 58 Edsel Ranger, 72 Cheyenne Super, many 49-60 parts cars, abandoned "House Of Doom" full of 49-60 parts. Huge piles of engine parts, brackets, tin, Hydramatic & Jetaway parts,  thousands of stainless moldings, dozens of perfect sedan doors.
Matt CLC#18621
I just got back from the car wash, the Ice cubes didn't work and the car wash used a cleaner and it too did not work?
Matt
CLC#18621
Ralph Messina CLC 4937
Matt,
Try a small piece of dry ice in a plastic bag.  Place a towel between the bag and your hand (That stuff will give you a nice burn. ) Once the gum is frozen it should peel off. Try not to deform the leather too much until it returns to room temperature as it may crack.
HTH,
Ralph
2018 GMC Yukon
ron anthony #23803
Call the local janitorial supply company. They will have a spray aerosol to effectively freeze the gum for removal.
Ron,
I never beard of the spray, but it sounds like a better method than dry ice. Do you know the name of it?
Ralph
2018 GMC Yukon
ron anthony
Ralph,
The stuff I have is called Gum Off by Allstar.  Paid 25 cents for the can at a Swap Meet.
Carpet Cleaners use it.  When I was a kid my little brother had gum in his hair and my mother worked it out with peanut butter.  You might try that, but always test on an inconspicuous area first when using any product.  Residual gum left from labels can be removed with mayonnaise.
Ron CLC 23803
Ron,
Thanks for the information. I’ll lkeep an eye out for it.
Ralph
2018 GMC Yukon
