1938 60S Serial Number Decode?
Started by thunder, February 19, 2008, 04:17:01 PM
thunder
Where do I go to obatin a decode of the Serial Number on a 1938 60 Special?
Jon
A going on 6-decades car guy
Don Boshara #594
The serial # should be: 627XXXX. The last 4 numbers would indicate the order in which it was built. Apparently there were 3704 production '38 60 Specials.
1940 Sixty Special
1966 Mustang Cpe
thunder
Don:
Wow, thanks a bunch!  Do you know if, in those days they began with an 0001 count, they began thre Model Year count at zero?
And  ...  BTW  ... is there a place I can decode the car's Trim Code 44?
Jon
Warren Rauch
 The model year count did begin with 0001, but serial and body numbers were not always used in order. The trim code 44 was Gray Novelty Bedford Cord for 1937 thru 1940. Your guess is probably better than mine what that is. Warren
Don Boshara #594
This is Tan Novelty Bedford Cord from a piece about 4" wide
1940 Sixty Special
1966 Mustang Cpe
thunder
Thanks guys!  This is great.  I am appraising a very nice 38 60S for a car guy's widow and want to get the details correct.
You have helped me alot and I really appreciate it.
Jon
