71 Heater core...what kind of job?
Started by Brett, March 01, 2008, 02:58:53 AM
Brett
How much of a PITA is a heater core replacement in a '71?
In 73 they come out from the inside.  The wost part is taking the dash apart to get at it.  At least in these cars there is room in the front seat to work on stuff.
Lars Kneller 8246
I did it not too long ago on a 72 Eldo Coupe, and it wasn't too hard. If I recall correctly, you have to remove the glove box, and there are 4 nuts on the engine side that have to be removed.  Then you can shinny the heater box out from the inside. Follow the procedure in the shop manual.  I think it took me 3-4 hours start to finish.  I did clean up the heater box, and glued new foam in that lines the doors.  The foam they sell at hardware stores for window air conditioner filters works pretty good. I glued it on with the 3M upholstery spray adhesive.
