saginaw steering
Started by jack oconnor clc 18960, April 07, 2008, 03:39:47 PM
I am attempting to replace the roller bearings in my saginaw steering box. The bearings are mounted with the worm gear on the steering shaft. I have been unable to disassemble these componants. Has anyone had this problem? Any suggestions? Car is a 1937 cadallac seiries 60. Thanks  - Jack
homeonprunehill
Quote from: jack oconnor clc 18960 on April 07, 2008, 03:39:47 PM
04-13-08
Jack, Sounds like it time to call in the BIG guns. Can you get to the bearings with a bearing-puller? I know that I won't be much help, But it may get you to thinking. Good Luk,Jim
