1939 Lasalle running bards
Started by Greg Mouton, April 24, 2008, 11:46:37 AM
Greg Mouton
 I am building a original car and a street / rat rod and I am intrested in running boards on therat rot mabe something street looking (just painted metal with a skid pad on top so Can these be made in a shop? what are the dimentions? and how were the originals attached ? were they connected to the fenders ?
Greg Mouton
Kerry Pilling
O.K. they are actually called running boards. Anyway they were attached by special angle brackets which were bolted to the frame between the front and rear fenders. I can't remember if there were three or four brackets. I imagine that you could get a good metal fabrication shop to make you a set of metal running boards with brackets and have them attach them to the fram then you paint them and can put non-skid strips on them for safety use. Good luck. Kerry
