1956 Generator Bracket Mounting
Started by Charlie CLC#18187, May 08, 2008, 01:01:36 AM
Charlie CLC#18187
I'd like to get a pic of the generator, showing the top bracket attachment to the engine.  My car had an aftermarket a/c unit- which I removed- and it seems something is missing, or the bracket was shortened.  Does it attach to the top water pump bolt?  Bracket does not allow enough adjustment the way it is now.  THANKS MUCH.
1956 Coupe de Ville
Quote from: Charlie CLC#18187 on May 08, 2008, 01:01:36 AM
Hi charlie
I have a picure from my Biarritz; maybe it will be good enough for you.
Good luck,
Roger
Charlie CLC #18187
Roger- That really is a beautiful engine bay.  Can you confirm that the top gen. bracket is attached at the upper water pump bolt- can't quite tell from the photo.  If so, looks like mine was shortened.  Thanks a lot! Charlie
Quote from: Charlie CLC #18187 on May 08, 2008, 07:04:22 AM
Thank you Charlie! Yes, it is attached to the upper bolt of the water pump. I know that the picture would not show it explicitely but I have other ducument showing that the upper bolt is the correct one.
Roger
Otto Skorzeny
The adjustment bracket on AC equipped cars is shorter than the one used for non-AC cars.
fward
HUGE VENDOR LIST CLICK HERE
John Morris #23947
I have the non air bracket if you need it.
71 Olds 98 LS, 66 Fairlane 500 XL Convertible, 55 Packard Clipper Super, 58 Edsel Ranger, 72 Cheyenne Super, many 49-60 parts cars, abandoned "House Of Doom" full of 49-60 parts. Huge piles of engine parts, brackets, tin, Hydramatic & Jetaway parts,  thousands of stainless moldings, dozens of perfect sedan doors.
Charlie CLC #18187
Thanks for the help on this all.
Charlie CLC #18187
Quote from: John Morris #23947 on May 09, 2008, 12:36:57 PM
John- I sent you an email on this.
Charlie
