'51 Series 62 Rear Fender Question.
Started by Rick Cerbone #20905, May 30, 2008, 12:39:42 PM
Rick Cerbone #20905
Hello.  I just wanted to verify that there should NOT be any fender welting between the rear fenders and the body of the car.  I am also assuming there is NO filler of any kind used between the rear fenders and body.  Thanks for any info.
homeonprunehill
Quote from: Rick Cerbone  #20905 on May 30, 2008, 12:39:42 PM
05-30-08
Rick, I think there is  a 1/4" BLACK welting between the body and fender. Virefy First. Wauit for a '51 owner to answer you, but I'LL BET folding money that there is welting.HTH Good Luck,Jim
Paul W Allen 20193
Quote from: homeonprunehill on May 30, 2008, 03:22:42 PM
05-30-08
Rick,
Yes, Jim is correct. Absolutely welting between the rear fenders and body, Always black, right up to 1953, the last year for it. In 54, the rear fenders and body were one piece.
Paul
homeonprunehill
Quote from: Paul W Allen 20193 on May 31, 2008, 06:45:06 AM
05-31-08
Thanks for coming to my rescrue, Paul. Rick, if you intend to put this on by yourself, "Order one foot more then necessary, start with ALL the bolts in place(loose). Start at one end and allow about 1/4 of the extra welting to hang out. First, take a sharp knife (razor knife or utility knife) ,cut almost to the bead and push the welting in place. With the welting in place, tighten the bolt enoult to hold welting in place. when done, go back and torque the bolts to spec. and cut off the over-hang.  HTH Gooed Luck,Jim
05-30-08
Rick,
Paul
Rick Cerbone #20905
Thanks for all the info.  You guys saved me from making a big mistake!!!  Any recommendation in terms of where I should purchase the fender welting?  If I can get this done in time I may see some of you in NJ!  Thanks again.  Rick
Paul W Allen 20193
Rick,
Steele has it. USA Parts Supply should also carry it.
Paul
