I didn't see any Fire Extinguishers at the cars in 2002 at the Dearborn GN.But I have seen pictures of car shows with then in front of the front wheels, and they look like they are doubling as Wheel Chocks.Luckily, this habit hasn't arrived here in Australia. And hope it never does.Bruce.
Bruce and others -- You may not have seen a lot of fire extinguishers on the ground at Dearborn in 2002, because we used a drive-through station judging process over two days, but believe me, fire extinguishers were checked at the first judging station, and a couple cars were turned away for lack of extinguishers. For those who object to this, I hope you never see a car fire at a show. They do occur, and that is the reason for the requirement. Paul Ayres
For the record I always have a first aid kit in my cars, but fortunately I never had to use it... The fire extinguisher has been used twice. Once for one of these PS fires and another time on a trunk fire(neither one was my car). It doesn't matter how low mileage of a car you have. Rubber deteriorates over time, not miles. Change out that Hi pressure power steering hose with a new one to avoid this kind of fire.
Bruce and others -- You may not have seen a lot of fire extinguishers on the ground at Dearborn in 2002, because we used a drive-through station judging process over two days, but believe me, fire extinguishers were checked at the first judging station, and a couple cars were turned away for lack of extinguishers. Paul Ayres
Quote from: Paul Ayres #5640 on June 07, 2008, 10:26:40 AMBruce and others -- You may not have seen a lot of fire extinguishers on the ground at Dearborn in 2002, because we used a drive-through station judging process over two days, but believe me, fire extinguishers were checked at the first judging station, and a couple cars were turned away for lack of extinguishers. Paul Ayres G'day Paul,Thanks for the explanation.I have just checked every picture I took in the Show-fields at the 2002 GN, and not one Fire Extinguisher in sight, anywhere, in front of cars, beside them, and one car even had a Texaco Petrol Container in front of it.Maybe the Show-field should just be called a Car Park?Bruce.
How about the interiors of the cars. as that is where the fire extinguisher is usually kept?
