Lock Cylinder Removal From The Ignition Switch
Started by Al Smith, June 23, 2008, 09:00:39 PM
Al Smith
I wasn't able to find any instruction in any manuals I have nor in the forum search here.(possibly not worded correctly?)
I need some guidance on removing the key cylinder from my ignition switch.
1951 series 62 sedan.
All help will be appreciated as usual.
Al 8)
G'day Al,
In most cases, there will be a small hole in the face, somewhere, where you can insert a straightened paper clip to release the tumbler barrel.
If there is one in yours, I think it is a case of turning the ignition on, inserting the pin to push a spring-loaded clip, and once that is pushed in, turn the key to the left, and it will release the key/tumbler as a unit.
Then it is just a matter of removing the outer bezel either by unscrewing it, or un-clipping it.
PS.   Remove the Negative Battery Terminal first.
Eldorado_64
That's right, once the lock cylinder is out w/ key, you can un screw lock bezel outward from ignition casting. Some are even hexed inside to use a socket if too tight and some are of the spanner nut type, Needle-nose plyers an be used to aid.
1964 Cadillac Fleetwood Eldorado Biarritz & Sixty-Special
Cadillac, "The Only Way"
