1959 motor
Started by paul, June 29, 2008, 02:24:45 AM
paul
Can someone tell me if the engine block on 1959 390 motor is the same as 1957 365 motor.  And are the heads the same on both motors.
Paul
Warren Rauch
 I checked Cadillac parts books (1960 and 1970) They both list different part numbers for blocks and heads. Hollander has the same information. The block is 1959 only , the heads 58-63 (note this would be the 63 head fitting back ,not the 59 fitting up in years. The new engine in 63 used a different valve cover)Warren
