Upgrading early 54 power steering to late 54/55 power steering
Started by PHIL WHYTE CLC 14192, July 03, 2008, 03:24:35 PM
Hello everybody, seeing as I have finally found out what's wrong with my power steering on my 54 CDV and I will have to have the steering box out , I was wondering if it would be a big deal to upgrade my car to the later 54 steering box ? I would , I assume need both the later box and steering shaft, is there anything else I would need? I have tried to be as factory authentic as possible with my car , but this will be the third time I have had to remove the steering box and it is a real pain when you have to dismantle the whole steering column.
I await your advice and suggestions.
Phil
