1951 convertible window rollers
Started by depmike38, July 15, 2008, 05:12:47 PM
depmike38
Is there a source for the correct side window rollers for a 51 convertible? I don't have enough left to size them and they drag so
badly you have to "help" the window up and down. I'm a bit lost it's my first older Cadillac. Thanks, Mike Freeman
Mike Freeman
P W Allen CLC# 20193
Hi Mike. I've done quite a bit of work inside the doors of my 53 Coupe. (all new side glass) I don't recall having any "Rollers" so to speak. There are window channels and slides on the scissor mechanism for the window lifts. With your car being a convertible, it has the hydraulic windows (power) yes? If so, the door internals on the  51 should be very much like the 53. Can you post a photo of what your calling a "roller"?
Paul
Paul
53 Coupe
Twin Turbine
vicbrincat
#2
Are these the roller you are talking about?
(Would love to know of a source as well as I am missing one, too. Four are needed for a Coupe or Convertible, two for the front driver and two for the front passenger window. One roller goes on the inside and the other on the outside to hold the window firmly in place as it goes up and down).
BTW, My  '53 Convertibles did not have these rollers...it may have been 51 or 52 and earlier that did.
Vic Brincat
Leo Fabian CLC#5365
Mike , I got rollers for my '49 conv't from Steele rubber, 2008 catolog, page 133, part #70-0117-62. They look just like the one in Viç's picture.  Leo
vicbrincat
Leo,
I got the rubber part of the rollers from Steele Rubber. They are perfect...but I am missing one of the four roller units (like the one in my pic).
Does anyone know where I can get one of these roller mechanisms?
(Sorry to steal your thunder, Mike).
Vic
depmike38
Hi,I'm back with a couple of pictures of the problem I've got. The darker photo is what the two rollers looked like as removed from the car. All that's left is the metal button, the nylon or plastic is completely gone. This is the passenger side and you can see how the rollers orient directly over one another so the window can slide straight up and down. In the second photo I've adapted a roller from a mid-50's Buick to the frame but it still needs a bit more shimming I think. Biggest problem is that without an intact roller to look at I don't know exactly where it goes to keep it from binding. Thanks,Mike.
P.S. While working on this I got some helpful info from one if not the original guy at Hydro-electric on how to do a pre-lim test on the pump and window rams if anyone needs it!
Mike Freeman
