All Cads
Author Topic: 1949 Parking brake  (Read 1047 times)
Dave, CLC #15849
  • Guest
1949 Parking brake
« on: July 31, 2008, 01:12:51 AM »
Just started working on a 49 60S. Fairly low miles, excellent runner, original upholstery, etc.   Parking brake handle doesn't hold.  the teeth are worn down so bad that the spring doesn't hold it.  I compared the shaft to later model handles, 51-55 and I noticed that on those cars the shaft is a solid piece of steel.. the 49 shaft is rolled, chromed steel, and it appears to be a milder form of steel, Does anyone have a good fix for this?    And the spring assembly seems weak. Maybe change to a 50's handle and bracket??? Anyone else had this problem? thanx. Dave
Offline Jeff Maltby 4194
  • 49 fastback
  • Deceased Member.
Re: 1949 Parking brake
« Reply #1 on: July 31, 2008, 09:28:58 AM »
You need to find a good 49 replacement.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
