Serial numbers
Started by 414door62, August 10, 2008, 12:42:54 AM
414door62
I have recently acquired a 1941-62 series 4 door. I am new to Cadillacs. Where is the vehicle serial (VIN) number. I can easily see the data plate on the cowl. I just do not know where to find the VIN number.
Thanks, Frank Porter
Frank
homeonprunehill
08-09-08
Frank, the S/N is stamped very lightly on the frame near the steering-box Welcome to the CLC , if you decide to join the club,grantee it will be the best $35.00 you will ever spend . Good Luck,JIM
414door62
#2
Jim , Thanks for the reply. I will go up to the shop today and get the numbers. Then I will try to find out about the history of this car. It is in very rough condition with a seized engine. My Intent is to restore it. I am in the dismantle phase right now.
I am sure i will post other questions as the process continues.
Tanks again, Frank Porter
Frank
414door62
Jim, You were right on target, the numbers where exactly where you said they would be (and hard to read).
Here they areon the frame,  8350886
Cowl tag numbers
Style ------------ 41-6219
Body number-- 3225
Trim Number--- 31
Paint ------------- 60
ACC - says top
Is ther an easy way to decode all this?
Frank
Frank
Warren Rauch
8350886 = serial number range for 41 series 62 ; 8340001 to 8364734
41-6219
41= 1941
62= series 62 this is next step up from series 61
19=5 pass sedan
  production 41-6219 =  8012
                 41-6219D = 7754 ( 4 door Deluxe)
                41-6219D CKD (crated for export) = 96
Total series 62 = 24,726
Total 1941 = 66,130
3225 = body number
trim 31=Blue gray Ribbed Cloth used on series 61 & 62
Paint 60 = Two tone Gray, Rivermist Gray on top (charcoal gray) and Dusty Gray on bottom ( tan color hint of gray)
ACC =none -sometimes factory install accessories are listed here by a letter or number code
top = used for color of conv top
These cars were the bread and butter of Cadillac production ,and made them the top company they are.
Warren
414door62
Warren, Thanks for the info. I am very impressed with the prompt replys.
Thanks to everyone.
Frank Porter
Frank
dwntwnab
i have a 62 4 door fleetwood. im haveing trobles finding the vin also. i looked around the steering box. didnt find a long number but did find a -20 stamped a inch or so off the steering box. can someone help me?
Nothing on the lt ft door post?
Chris Conklin
For '60-'62 it is on the top of the left side bar near the radiator support.
Chris Conklin
