1941 hood nose trim
Started by arturoquijano, September 07, 2008, 10:22:54 PM
arturoquijano
I want to know if the hood nose trim (the Chrome lip of the Hood) of the 1941 cars is the same in all series Is say a hood nose trim removed from a series 75 will be fit in a 62 series car?
tanks
Bill Ingler #7799
My Master Chassis Parts book shows only one part number used in 41. Part #1440786. If you are going to plate a used hood lip, pick the plater carefully as these lips can be warped in the plating process and then it becomes difficult to get a proper fit with the contour of the hood.
Doug Houston
Also, if warpage won't be bad enough, the little end pieces on them are EXTAREEEEEMLY delicate. Alert the plater to it, if he can't see it for himself!.
In addition, make sure that the nose piece is securely bolted to the hood when you install it. Flexure of the hood can break them.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
Arturo Quijano
#3
Thanks  for your valuable information and tips.
Arturo Quijano
#4
Thank you for your tips
