58 cadillac points
Started by g, September 20, 2008, 02:45:13 PM
g
hello, i just got a set of points for a 58 cadillac 365 v8, how do you put them in and set them? any help would be appreciated.
thanks
George
If its like the later GM stuff you remove the cap and rotor, both are indexed so you dont have to worry about alignment.  You can leave the spark plug wires hooked to the cap.  You will then see the points set. You then bump the starter or turn the engine by hand so the points are at their max open point. Typically there are 2 mounting screws and a screw that holds the wire that goes out to the coil and a short wire that goes to a little metal can that is right next to the points.  The can is called the condenser and is typically replaced with the points.  You install the new set and connect the wires.  The next step is to set the gap.  To set the gap you use feeler gauges just you use for setting plug gaps.  To change the gap between the contacts you turn that screw with the spring under it. Once this is set you put everything back together and connect your Dwell / Tach meter and start the engine.  Set meter to dwell and through that little door in the side of the cap turn the same screw you set the gap with till you get the proper reading on the meter.  The gap and dwell are part of the 'tune up specs'.  Gap gets you close, dwell is much more precise.  When its set properly the engine runs much better.  If your new points wear out quickly its usually the condenser being bad, it sort of quenches the arc across the contacts to make them last longer.
57Fordman
I was wondering if you could help me with my 58 Cadillac distributor problem?  I can't turn the distributor in order to set the timing.  The hold down bolt is removed and I have tried some penetrating oil at the base of the distributor.  I posted a separate notice under 57 Fordman but so far no one has responded to it.
Thanks, Jim
Jim Blodgett
Maple Valley, WA
CLC #6405
1958 Sedan Deville Senior Car
G'day Jim,
The biggest problem with a stuck Distributor is that it is stuck, and sometimes, no amount of pulling, twisting, yanking etc will free it.
One suggestion would be to build up a "Dam" around the base with plasticine, and fill the area between that and the Distributor with a Penetrating Oil, and let it sit, topping it up when necessary.
This way, the oil will seep its' was down between the shaft and the block, and with an occasional attempts to twist or tap, it will eventually, hopefully, come out.
Walter Youshock
Hi, Jim.
Check your other post.  I replied yesterday...
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
homeonprunehill
10-07-08
"57Ford,is there a small door in the dist.cap? I had a '57 Chevrolet, that the points were adjusted useing an allen wrench thru. the door in the dist. cap. HTH Good Luck, JIM
#6
With the small door in the distributor cap you can only adjust the gap, not the timing.
Big Fins
#7
But, if you use a timing light and watch it while you are adjusting the dwell, you will find you are changing the timing by opening and closing the gap on the points. A change in dwell also changes base timing.
Therefore always set the dwell, THEN set the base timing.
Fins
