93 sedan heater core
Started by Dan Marinola, September 30, 2008, 09:06:33 AM
Dan Marinola
Does anyone know how to remove the heater hoses from the heater core on this car? I have the tool to remove the clamps,but how do you remove the hoses? Will they pull through the firewall to the inside of the car? HELP!!!!
Guidematic
 The heater hoses have to be removed from the lines from the core. They will not pull through. They can get stuck on there pretty good. Try twisting them. I know the space is tight, though. If not, you can use a good razor blade and cut a slice through them, insert a screwdriver and peel them over. But you will have to replace the hoses then.
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
Ohio57-62Sedan
 hey Dan I would just use a big pry bar.and they will pop off. are you replacing the heater core ??
Dan Marinola
Hi John,yes I am replacing the heater core,and its not a nice job! Why would any engineer do this to a mechanic I dont know. Ill try the pry bar and see what happens. Stay tuned. Thanks for the reply. Dan
Ohio57-62Sedan
 :D :D I just thought, if your replaceing it, what do you care what you do to the core?   :D :D I know it's not an easy Job.after your upside down for a while the swelling in you eye's will go down. and put a fender cover or towl over the door panel  it's a nice place to rest your leg's.  Trust me your not the only on looking for an engineer, after you have had a few to drink!!! They don't have to fix the dam thing, it just has to work.. Take your time on the inside all that stuff is brittle
Guidematic
 Engineers leave us guys all kinds of these little gems. You get used to it after awhile.
You can get brutal with a pry bar if you have no further use for the heater core. But watch the hands if the bar slips off!
Ohio57-62Sedan
that why they call us busted knuckle's...    :D
Guidematic
 And I've got lots of those too.
