Alignment specifications for 1966 Cadillac Sedan deVille
Started by K. T., October 08, 2008, 02:55:44 AM
K. T.
I would appreciate good advice as to what alignment specs should be on the front of the Cadillac. I have American Classic 235/75/15  1.6" ww tires.
Again, this is for a 1966 Cadillac Sedan deVille with radial tires.  Thank you.
1/8 to 3/16 toe in , camber is .4 degrees positive, the issue here is with radials on any pre radial car you need to get at least 1.0 degree positive caster for proper tracking with the radials, gas shocks should installed also for proper handling. The caster issue is an often missed item when putting radials on.  Make sure who ever does the alignment does not upset the camber setting to achieve the postive caster.
