'57 Eldorado Gold Package
Started by James Mundstock, October 12, 2008, 11:41:46 AM
James Mundstock
I need verification for a freind. He is looking at a '57 Eldorado that he is being told it has the gold package and has a gold grille and gold sabres. I checked my parts manual dated up to January 1959. I can find a gold grille and a stainless grille. When I look up the sabre part numbers, there is only a part number for chrome sabres. I thought that '56 was the only year for gold sabre option and I know the '56 rims won't fit on a '57 without modification. Was there a gold package in '57 with gold sabres and my parts manual may have them obsoleted by the date of January 1959? Thanks.
Warren Rauch
 I looked it up in a May 1,1957 parts book . Only the Chromium plated type were avalible (of course the series 75,CC had a heavier version). Then I looked it up in the" 1957 New Car Speciications Manual" (print date Oct1956). There was a code G , gold package. It was an optional gold grille only, in 1957 and at no cost on the Eldorado. The sabre wheels are listed as chrome and standard equipment .This should cover the whole year. Is there a "G" code listed on the body tag? Warren
okccadman
Gold Sabres were offered in 1956 only.
Jim Jordan CLC# 5374
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
56 Fleetwood 75 Derham Limo
59 Fleetwood Sixty Special
66 Fleetwood Brougham
66 Superior Hearse/Ambulance
67 Fleetwood Sixty Special
68 Fleetwood Eldorado
76 Coupe de Ville d'Elegance
90 Brougham
92 Fleetwood Coupe
93 Allante
94 Fleetwood Brougham
02 Eldorado Commemorative Edition
Walter Youshock
Gold Sabers were ONLY available for 1956.  The gold grille option was a no-extra cost item for the Eldorados, as was the "Q" engine.  The gold grille was a $35.00 option on the rest of the line and the "Q" engine was NOT available on the rest of the cars, although a few may have slipped out of the factory.  The only car that came with the "Q" engine as standard in 1957 was the Series 70 Brougham.
Also, the gold trim was anodized aluminum, not 24K gold plated.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Ohio57-62Sedan
Walter. what is the part mumber for those of us that want to use Sabre wheels ?  there are two numbers right?
Bill Balkie 24172
Hello,
If you wanted to use the 1956 gold wheel on the 1957, Would you have to use a spacer ? and if so, how Thick  should the spacer Be ? The other question is , if you use a spacer will the studs be long enough ?
Thanks , Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
Walter Youshock
#6
I don't have access to the part numbers right now, but much has been written here.  If you do a Search for "Sabre Wheels", it is probably in an older thread.
The '57-'58 wheels will work on earlier cars, but the earlier ones won't work on the later cars because of the brakes.
Actually, Stampie has a set of gold '56's on the Buy/Sell forum now:  http://www.cadillaclasalleclub.org/forum/index.php/topic,103206.0.html
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Walter Youshock
I posted this to another thread, but I feel it belongs here as well:
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
