Vacuum Diagram
Started by Shiner, October 31, 2008, 10:34:12 AM
Shiner
Hi All:
Am needing a vacuum diagram for a 1958 Cadillac.  The routing for the windshield
wipers is what's needed.  I have shop manuals '57 & '58 however cannot locate
anything there. Any help would be appreciated.
BRIAN H HELWEG
Walter Youshock
Brian,
Here are copies of some factory literature.  If you have trouble, please let us know and we can walk you through it!
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
David King (kz78hy)
Mastermind sells the molded 4 hose tubing and claims to have a routing diagram.
Here is the link.
http://www.mastermindinc.net/Rubber%20Parts.htm
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Shiner
Hi again all:
Thanks for response,exactly the info I needed.
Much appreciated.
BRIAN H HELWEG
Walter Youshock
On my '57, I found that unless the washer tank is kept full, the car will not run smoothly.  The vacuum system relies on the washer/wiper system being in working order.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
