1928 LaSalle wheel conversion from artillery to wire
Started by Bill Bickle 15098, November 02, 2008, 08:44:17 AM
Bill Bickle 15098
I have an opportunity to purchase a set of wire wheels for my wood spoked wheel 1928 LaSalle. I have researched the master parts list and the conversion seems quite possible without much hassle.  Has anyone done this conversion that could tell me what problems I am about to encounter? Your advise is definitely appreciated.
1927 (7400) and 1940 (5267) LaSalles; 1949 Cadillac 6107
Wayne #17075
Hi Bill, Wayne here. I did the reverse on my car. The main problem was that I had two cars side by side...took one axle out  and put it in the other car. The thing that screwed me up was taking the stbd axle out an putting it into the port side of the next car....Turns out one side is longer then the other!! After days of pulling hair...or what's left of it, I figured out left goes to left, etc. The hubs on the two different cars or axles are different and it was easier for me to just switch the axles and seals (which I have spares of).  If it turns out that you have a good artilery wheel, let me know. One of my spares is less then wonderful...it's got sa few cracks and rot in it.
Wayne
