Heater Cores - Available as New?
Started by Jack McClow CLC #15840, November 13, 2008, 11:32:09 PM
I am beginning the next phase of restoration on my '57 convertible ........... I have a list of things to locate and the first on the list is a heater core ........ is there a source for these as newly manufactured?  Or is a re-core of the original the only option.
Jack.
JIM T.
11-12-08
JACK, If you can't fine a NOS heater core, Have that one re-cored.The RAD. SHOP will pressure-test it before releasing.Good Luck JIM
Hi Jim,
Thanks for your reply.  I didn't even try to look for a NOS heater core ....... I was (am) afraid it would be much less reliable than a re-core ....... I've never seen any for sale anyway.   I have looked all around for a place that might be making new cores to fit my car, but had no luck.  So I guess we'll go with a re-core of the one from my car and move on to the next problem.
Thanks again,
Jack.
walt chomosh #23510
Jack,
  My 1955CDV had a heater core leak,and my local radiator shop went to his suppliers catalog and found the correct size.(my core was 50% larger then most cores!) I believe he put my ends on the core.....walt...tulsa,ok
Thanks, Walt, so much for sharing your experience.  It was my thought we would follow the same process, with my car, as you did with yours, but my restoration guy wanted me to at least check around to see if any firm was manufacturing new complete cores ...... I hadn't been able to find anyone doing so, and you and the other replies to my post have confirmed what I had been told during my search.
Thanks for the help,
Jack.
