1957 6-way seat repair
Started by TommyO, February 01, 2009, 12:17:16 AM
TommyO
Many Thanks  Walter for your input on the bumper issue.  I have a Series 62 Convertible.  Another Quick Question--who out ther in Caddy land rebuilds seat mechanisms for a six way power seat same vintage??  Again, Thanks...
Tomeo
Walter Youshock
Don't know.  Buick and Olds should be the same as Cadillac, but far rarer.  What's wrong with your seat mechanism?
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
TommyO
My 1957 six way power seat, responds sometimes as it should, and other times just slips and makes funny noises!  I have Not  removed the seat from the cart as I do not want to open a kettle of fish that I do not know how to put away!  I am however in the process of reupholstery real soon, and would like to have the seat issues corrected at this time!  Many thanks beforehand for any insight!  thanks,
Tom O
Tomeo
Walter Youshock
We're going WAY off the original topic here.  My guess is that it is a sticky solenoid or, the seat is actually hitting the end of its travel.  Do you have the Shop Manual?  The seat mechanism is one motor that turns a jack screw that turns in 3 different solenoids that move one of 3 torque rods depending on what part of the switch is activated.
The only way to fix it is to get the seat out of the car.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
J. Gomez
Tom,
Walter is correct, the only way for you to ascertain on finding and fixing the problem is by removing the seat.
I just finished working on my 1956 6-way seat the seat adjuster assembly, the electrical (motor and solenoids) and redoing the wire harness. As Walter states, the motor and solenoids work in conjunction with each other to provide the correct seat adjustment; this is all controlled by the individual switch positions.
Moving the switch to any position will active the motor and at the same time will activate the particular solenoid to perform the function.
Good luck..!
J. Gomez
CLC #23082
Coupe
If the motor is working chances are it's either one or more of the solenoids are not activating due to a broken wire or the old grease is binding them up. My '57 suffered from both issues when I bought it. I soldered the wire back on and cleaned and greased the entire assembly, solenoids, jack screws and linkage etc. Works fine now. My guess is the wire broke when the previous owner tried to fix the problem without removing the seat.
1957 Coupe de Ville
1993 Allante
1949 Jeepster VJ-2
TommyO
Apologies to all for going off topic.  Still searching for my original issue!@  Need a shop manual.  Thanks to all for help and insight!
Tom
Tomeo
The best place for a Shop Manual is firstly, Crank'n Hope Reproductions in Blairesville, PA, or ebay.
The ones from Crank'n Hope are just as good as the original GM publications.
kelly
Odly enough, a company in my home town of North Branch, MI, produced the worm screw/gear used in many '57 Cadillac power seats. They are still in business! I had a problem with the 2 way power seat in my '57 75 series, but it wasn't the unit itself.  The wiring harness that feeds power to the seat motor runs aft beneath the left hand floor/rocker cover panel. The connection that splits off to the seat motor is a twist/solder/tape arrangement, and upon inspection, mine was all nasty green and corroded. Simple fix in my case.
  If you find that the steel worm screw/gear is FUBAR, let me know. I will see if M.K. Chambers can make replacements for you from old specs/prints.
Kelly Martin
Kelly Martin
1957 Fleetwood 75
Dan Koser
Quote from: J. Gomez on February 03, 2009, 06:19:00 PM
Tom,
Good luck..!
I've been gone for a long time, but am back at the '57 Series 62 2-Dr. HT, and would like to know if there is a tutorial or some such on removing/repairing/reinstalling the seat solenoids on this car? Any information would be appreciated. My son and I lifted this seat out and I tore my rotator cuff in the process, so BE CAREFUL...this seat weighs a TON!! Dan
Dan Koser
I found this great link describing in detail the functioning of the power seat:
http://www.eldorado-seville.com/files/tag-6-way-power-seat.php
What is not here is how to repair a solenoid, so that remains my question for the moment....my seat works except for the fore and aft adjustment.  Dan
J. Gomez
Quote from: Dan Koser on July 31, 2016, 11:41:24 PM
Dan,
??? Not clear from your post if you have done any troubleshooting on the solenoids.
If you disconnect them and apply a direct +12V source at the connector, do they energized?
If they do you may have a problem at the switch.
You can check the following thread as it has some details that could help you, PS the ’56 and ’57 are similar.
http://forums.cadillaclasalleclub.org/index.php?topic=141542.0
Good luck..!
J. Gomez
CLC #23082
BillR. CLC # 29203
Dan,
Super information and graphics associated with that link.
Thanks for sharing.
Bill Rodwick
Bill Rodwick
CLC # 29203
Crew Member:  '59 Sedan Deville Six Window
Dan Koser
Quote from: J. Gomez on August 01, 2016, 09:10:04 AM
Dan,
Good luck..!
The only trouble shooting I've done is to note that, thought the motor energized, the seat will not move forward or backward. What is the procedure for accessing the internal parts of the solenoid? I will apply the voltage to test, but I still see the need to disassemble, clean and reassemble and that's where I'm stuck. Dan
J. Gomez
Quote from: Dan Koser on August 01, 2016, 02:15:07 PM
Dan.
If you have a ’57 shop manual Section 17 has details on the 6-way seats starting on page 17-44. The steps on the shop manual should give you additional details on troubleshooting yours.
Good luck..!
J. Gomez
CLC #23082
Dan Koser
Quote from: J. Gomez on August 01, 2016, 03:18:17 PM
Dan.
Good luck..!
It does, but it does not answer the question "What is the procedure for accessing the internal parts of the solenoid?" Section 17 talks about replacing the solenoid under certain conditions...this thread is about cleaning and repairing them and putting them back in service. To do that, the internal parts must be accessed, and that is my question: how? Dan
J. Gomez
Quote from: Dan Koser on August 01, 2016, 06:05:40 PM
Dan,
The solenoid internal is straight forward and only a few pieces can be removed such as the plunger, the spacer, trip plate and the metal ball bearing. The rest electrical coil and spinning nut that rides in the worm screw are non-removable.
Attached is the previous page from the Delco bulletin for the 6-way seat motor from the one I’ve attached to “1956 six way electric seat - solenoid replacement” post.
HTH
Good luck..!
J. Gomez
CLC #23082
Coupe Deville
Quote from: Coupe on February 04, 2009, 08:41:31 AM
x2
Same thing on my 57'. Cleaned up the transmission and solenoids, re-greased, and it worked like a charm. I also added a ground wire directly to the seat trans. case. That solved some problems as well.
Sometimes the ground gets overlooked on old cars.
Best of luck
-Gavin
Dan Koser
Quote from: J. Gomez on August 01, 2016, 07:10:33 PM
Dan,
HTH
Good luck..!
Very helpful...thanks. Dan
Dan Koser
Quote from: Coupe Deville on August 01, 2016, 07:58:55 PM
x2
Best of luck
-Gavin
Gavin, you say you cleaned up the solenoids....did you have to remove the seat from its frame in order to get to the parts in each solenoids? I have been able to get to most of the parts of the front solenoid, but the middle and rear ones look very tough without the seat being removed from the frame.  Dan
