Installing a 4 in 1 tachometer
Started by 1969 Coupe Deville, February 11, 2009, 08:25:01 PM
1969 Coupe Deville
Ok guys I have a tough one.  I have purchased a 4 in 1 tachometer, water temp, oil press, and oil temp meter.  The manuf of the meter is "Type R".  I need to install it on my 1969 Cadillac Deville 472 big block.  The manual is no help.  It has the brass hookups for each device, but no instructions on where to install them on the motor.  If this is not enough info let me know.   I will try to answer any questions.
Otto Skorzeny
You might get some help at these two Cadillac forums that deal more with modifications. Some people may have installed similar gauges already.
http://cadillacmisfits.com/index.php
http://www.modifiedcadillac.org/forum/index.php
fward
HUGE VENDOR LIST CLICK HERE
