Rusty has given you a good introduction as to the different 390's. The other problem is telling a 390 from a 429. There were changes to the exterior components. The air cleaner inlet tube is cone shaped in 63 and cylinder shaped in 64. The exhaust pipes were slightly (2 1/4 vs 2 1/2) bigger in 1964, and the exhaust manifold on the right was changed, the starter changed .The best way to tell are the two numbers on the engine. The serial is stamped on the right side below the soft plugs. It can be hard to read.IT will start with 63 for 1963. The other number is the engine unit number. It is stamped to the rear of the cylinder heads on the top of the crankcase area.For1963 it will start 36x ,36K 37X or 37K. the 3= 1963,6=most models,7= limo or Comm Chassis,X= non air cond, and K= air cond.Warren
