'59 Rear view mirror glass removal
Started by Ralph Messina CLC 4937, February 17, 2009, 12:22:53 PM
I’d appreciate any help in the proper way to remove the glass mirror from the metal housing of a ’59 interior rear view mirror. I have to do some restoration of the housing and don’t want to experiment on a fairly nice piece. Also what is the best way to reattach the glass mirror when I’m finished?
Ralph
2018 GMC Yukon
Walter Youshock
I've had luck using a plastic knife.  On the top, opposite the adjuster, at the center, carefully get the blade between the housing and the glass.  Work the knife to one side and the gals will either break or pop out.  I only had one break on me.
To reinstall it, lay it in the housing lengthwise.  Flip the housing over onto a towel and push on the corners of the housing.  It should pop back in.
There is or was a man in PA who repaired/replated mirrors by the name of Kaufmann.  I have his card at home.  Not sure if he's still in business.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Bill Lucarelli #22702
Ralph...great question, Thanks for posting and Walter for answering.......then what is the removal and reinstall for a 59 round outside door mirror?  Thank You
1959  Eldorado conv
1958  Porsche speedster
1948  Plymouth woody
Cirilian
Bringing this back up since I have the same question that Bill had. Has anyone removed and repaired/replaced their door mirrors on a '59??
R. Lopez
Guys,
I should have posted my results in removing the mirror…..I wasn’t very successful. I followed Walter’s advise and loosened the frame around the glass but the mirror none-the-less cracked when I tried to pop it out. ( That’s no reflection on Walter’s advise.) I didn’t find any evidence of adhesive; but the metal edge was rolled very tightly around the glass. I spread the frame quite a bit, to the point I wasn’t sure how I’d get it snug around the glass when I was done with the frame. This is one of those specialized tasks I probably should leave to a pro.
Ralph
2018 GMC Yukon
ray w.
I use a piece of plastic sheet, the  type used on advertising signs. It is firm but very flexible. You can also find it at office supply shops. Take a piece of it and slip it between the glass and housing and the glass pops right out.
ray w.
I forgot to add do not over spread the housing or it will never sit tight against the glass.
I will give the sheet plastic a try, sounds like it might be a better option.  I tried the plastic knife method but stopped as the knife seemed to thick to go inbetween the glass and the metal surround.....Thanks for the updates.
1959  Eldorado conv
1948  Plymouth woody
