Non working winshield washer on a '83 Seville.
Started by Wynn Moore, April 29, 2009, 10:19:34 PM
Wynn Moore
Windshield washer on '83 Seville stopped working.  Most likely its the washer pump attached to the wiper motor....but before I get a new one, I have one question, concerning the pump that goes in the reservoir.  Is the sleeve that is around the tube and filter supposed to be loose or is it supposed to be attached to the top?
Walter Youshock
That's the float for the "WASHER FLUID" light.  All the parts for the pump are on the wiper motor.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Wynn Moore
Quote from: Walter Youshock on April 30, 2009, 01:42:25 PM
Is this part still available?  I have searched the Internet with no luck.  I have been told that mine is worn at the top, and might not work.  Is this part absolutely necessary?
Thanks in advance.
Walter Youshock
Is your "WASHER FLUID" light on the dash always on, or did the bulb burn out?
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Wynn Moore
Quote from: Walter Youshock on April 30, 2009, 03:24:34 PM
Good question.  The light has never gone on, and the reservoir is full, so I don't know if the bulb is burnt out.
One way to check the light is to pull out the fitting in the Washer Bottle and allow the float to drop to the bottom of the shaft.
This allows the Magnetic Ring to come away from the cap and open or close the internal contacts, which in turn operates the light, as though the water level is low.
Then, when you turn on the Windscreen Wipers, the Low Washer Level light should illuminate.
On my car, the light only works when the Wipers are in use.
Wynn Moore
Quote from: The Tassie Devil(le) (Bruce Reynolds) on April 30, 2009, 08:31:18 PM
Thanks Bruce, I will try that.
homeonprunehill
Wynn, doesn't the "low fluid"light come on dufring start. Jim
70's Gm pumps were mechanical driven.  If its on the wiper motor I would bet its the mechanical style.  There is a solenoid that when activated allows the pump piston to catch and then drive on a cam on the wiper motor.  I have seen them where things get messed up with that catch and cam.  Most of the time when the pump quits its just the check valves.  You can buy a repair kit from most parts stores that is the top of the pump with the valves in it and an o ring gasket.  If that does not do the trick you can also buy the complete pump which is basically the whole plastic cover portion of the wiper motor.
Walter Youshock
I thought we were talking about the float on the washer reservoir.  That is the trigger for the light.  On an '83, the washer motor is integral with the wiper motor.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Wynn Moore
Quote from: Walter Youshock on May 01, 2009, 10:52:53 AM
Actually Walt, I was sort of talking about both.  Initially I inquired if the float would have anything to do with the failure of the washers.  Apparently it does not, then the info switched to the pump itself.
Wynn Moore
Quote from: TJ Hopland on May 01, 2009, 10:22:04 AM
Thanks to you TJ and everyone else that offered help.  I will perform a couple more basic checks and if it still doesn't work, I will just go get a new pump.  They are reasonably priced, about $50, and relatively easy to replace.
