95 brougham
Started by TommyO, May 07, 2009, 04:00:08 AM
TommyO
shift selector stopped working at exactly the same time power door lock engagement did.  Anyone else experience this?  Solutions greatfully accepted! :)
Tomeo
If you mean the shift indicator in the dash doesn't move even when put in gear, this is usually caused by the prndl sensor/switch on the trans.
TommyO
The symptom is that exactly!  The automatic power door lock that locked the doors also stopped working at the same exact time.  Obviously related??
thanks for any info!
Tomeo
