1961 cadillac carb
Started by 61 cad, May 08, 2009, 05:09:49 PM
61 cad
Hi i was wondering if anyone knows the cfm on a stock carb for a 1961 cadillac i think i have a carter .... i noticed my car is running to lean and my plugs are almost white color.
thanks
61,
Air flow quantity has very little to do with the mixture consistency.  What is it that makes you think your car is running too lean? Is it stumbling, surging or other sign, and what fuel are you using?
Greg
61 cad
it bogs from the start a little bit, the spark plugs are new with around 200 miles on them and the color is almost white, I only use 91 ... i think its running lean but i might be wrong
61,
At first blush I would suggest you rebuild the carb and replace the accelerator pump (or have the carb done by someone capable) and as well as cleaning out the jets, etc. all the rod adjustments should be done to specs. New plugs should be close to the color they came out of the box which is white.
Does the car idle well, and when you are at highway speeds driving up a grade is the engine smooth?
Greg
Dan LeBlanc
670cfm seems to ring a bell.  Carter or Rochester?
Dan LeBlanc
Carter AFB for Cadillacs peak out in 1966 at 625 CFM.
