Tire Pressure Monitor Question
Started by Dennis DiNorcia CLC 19071, June 01, 2009, 01:18:37 PM
My 2006 DTS shows "Service Tire Pressure Monitor" and there are no readings for any of the tires. I just bought the car and it was recently serviced and I was not told if the tires were rotated and if they were they should have relearned the tire pressures in all four wheels, I see in the owner's manual there is a way to reset it. Should I try this first before I go back to the dealer? How difficult is it to do, it seams easy enough? Thanks for the help.
jeff1956
on chevys you put it learning mode and adjust the pressure up then down unrtil the confirmation honk...start pass side then work way around. you have 5 min to set all 4 or you must start over. dont worry about getting the pressures right until all four are relearned...the dealer uses a tool to reset them not sure if it cosrs or not.
jeff
Dan LeBlanc
I believe I read somewhere once that if the tires are rotated and the TPMS is not reset, that could bugger up the system also.
Dan LeBlanc
johnh28650
Hey, next time u have a TPMS question just check out whytpms.com, thats where i go when i dont know what to do and my sensors are behaving funny.  :)
Mike Josephic CLC #3877
If you rotate the tires with this system, you must reset the TPM system computer or else
you will keep getting "alerts".  I have it in my 2004 Escalade.
A proceedure is in the Shop Manual but perhaps is best left to the Dealer.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
