Stromberg Choke Spring
Started by autoluke, June 18, 2009, 10:58:27 AM
autoluke
After  reassembly of my Stromberg  AAV-26 , I  am somewhat confused as to the position of the small l spring which wraps around the  fast-idle  linkage.  Need  a sketch, or  directions.
PHIL
Phil Lukens
Bill Ingler #7799
Hi Phil: Here are two pictures and I presume this is the spring you are talking about. One picture shows where one end goes through the hole on the onloader and the other picture shows the other end which fits under the grove that you will see on the end of the rod which goes up to actuate the accelerator pump.
Bill Ingler #7799
Here is the picture of the spring end attaching to the unloader
autoluke
Bill:
Many thanks  !   Sometimes it is just the small  problems which bring us to a complete halt.   Your photos did the trick.
PHIL
Phil Lukens
