Check oil when the engine is hot or cold for a 58 Caddy
Started by MyBlackCaddy, June 18, 2009, 10:07:47 PM
MyBlackCaddy
When the car is hot should the oil level be showing full or low?
Pat Flanagan
Ohio57-62Sedan
What kind of question is that?? first off you check your oil with the motor off. Hot or cold make not a bit of difference...wait a few minutes and then check it when all the oil get's back to the crank case... ::)
Otto Skorzeny
#3
Quote from: MyBlackCaddy on June 18, 2009, 10:07:47 PM
When the oil is hot it will be slightly above the "full" mark on the dipstick due to normal expansion from heat.
The only truly accurate reading of a dipstick is to check your oil when the engine is cold and the car is sitting on level ground. Check it in the morning after it has sat all night and cooled off.
fward
HUGE VENDOR LIST CLICK HERE
EAM 17806
Quote from: ottoskorzeny on June 18, 2009, 11:05:04 PM
The only truly accurate reading of a dipstick is to check your oil is when the engine is cold and the car is sitting on level ground. Check it in the morning after it has sat all night and cooled off.
RIGHT ON OTTO!  That is the only proper way to check the oil if you want a true reading. EAM
Ev Marabian
1976 Cadillac Coupe DeVille, 1989 Chevrolet Caprice Classic, 1990 Pontiac Bonneville and 1996 Buick Skylark
If you are suspecting oiling issues checking it hot and then comparing it to a cold check will give you an indication if you are having drain back issues.  Some overhead valve engines are prone to having the drain back holes in the heads plug up and cause the oil to build up in the heads.  In extreme cases it can end up starving the engine for oil.
Guidematic
Quote from: TJ Hopland on June 20, 2009, 09:14:24 AM
That was an issue with HT4100's. The drain back holes were small and tended to get restricted.
On N* engines, even GM suggests waiting at least 20 minutes after engine shut off to check the oil since so much oil remains in the heads that it takes that long to properly drain back to get the correct level. Because of this many thought their engines were using oil when in fact they were not.
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
Rusty Shepherd CLC 6397
Quote from: Mike Jones on June 20, 2009, 01:16:23 PM
Just when we thought we'd heard every problem with the HT4100 (and the list was longer than any engine since the Lincoln-Zephyr V-12) , Mike gives us another one.
Ohio57-62Sedan
    I was thinking should I put a N* Or a 4100 in the 57 ? I know the N* would have more power but I love my 4100's.. I've gotten 100,000 easy miles out of each one I've ever had.. I just wanted to hear what the Pro's have to say about it...
Otto Skorzeny
#9
I'm not a pro but I will say that you, being a professional mechanic will undoubtedly be able to get the maximum life out of any engine, even a lemon like the 4100. A typical owner/driver with daily use would have a hard time reaching that milestone.
Someone who knows his engine inside and out the way you do, is going to be way ahead of the curve on getting a 4100 to last like that. It requires a strict discipline and diligence to every aspect of the engine's finicky nature. Even an above-average owner/driver will have difficulty heading off problems.
Obviously it can be done but few are willing or able to devote that sort of attention to their driver.
100,000 miles is a lot for a 4100 but it's still pretty pathetic compared to just about any other engine out there.
I'd rebuild the 365 that's in there already. At 300hp it's got enough power to do whatever you want with the car.
fward
Ohio57-62Sedan
Thanks Dr.Otto I think you 100% right maybe ol blue is just too heavy for such a motor... New plan lets find a supercharger for the orignal motor... or what are your thoughts about going with a twin turbo... hmmmm sounds like fun to me
Otto Skorzeny
Get another 25 horsepower with the Eldorado engine. Twin carbs - that's always fun!
fward
Guidematic
Quote from: Ohio57-62Sedan on June 20, 2009, 11:11:25 PM
You're a funny guy, John. I like your fishing method.  ;D
Ohio57-62Sedan
#13
MMM.... BEER..... here fishy fishy .... ;D
Pat Flanagan
Quote from: Ohio57-62Sedan on June 18, 2009, 10:20:00 PM
It is a legitimate question from someone wanting to learn more about the car from the professional on this forum. You are the kind of a$$ that run new people off. It does make a difference as you can read from the competent people in the replies. " There are no stupid questions, just stupid answers.
Thanks to all for the replies. The problem is when checking the car cold the oil is full anytime after driving it is on the add mark. Now I know to let the car sit or cool before checking.
G'day Pat (MyBlackCaddy),
Yes, some people have funny ways of answering, but I always check the oil in my engines when it is cold, the engine is cold, that is, and note the level on the end of the Dipstick.
Actually, I pull the Stick, wipe it, re-insert it, then pull it again and that is the reading I go by.
The full level on the stick is where it should be, and after the engine warms up, it should read a fraction highwe, as the heated oil will expand to a point.
When I check the engine when it is hot, I always wait a period of time before checking it, and that is usually done after I have completed filling the Fuel Tank at the local Bowser, or if I am going on a trip, wherever the Bowser is.
If you know your engine doesn't use, or lose any oil for a period, then it isn't necessary to check as often as if you are losing, or using a lot.
Bearing in mind, that any car that gets a lot of stop-start motoring, gets to go on a long trip, the oil level can appear to use a lot when checking, but that is usually just the condensation boiling away as the oil gets very hot.   This gives a lot of people the idea that all of a sudden their engine is worn out.
Hope this answers your initial question.
Ohio57-62Sedan
Quote from: Pat Flanagan on June 22, 2009, 11:03:36 PM
Me Flanagan,
     I do not believe you asked the question, did you? I was not out to offend anyone here, but to me checking the oil is inline with filling the tank of a car.. This is all second nature to me.. So say what you will..Your not the first or the last person that will call me an asshole.  in my opinion if you don't know how to check your oil don't do it.. let a professional do it for you... I have 35 years in the automotive service ind.. and there are plenty of people that will never open the hood on any car. why?? because they are not mechanics... and as for expansion I would love to see something written about that... If that where true something would be written in the owners manual years ago don't ya think.. So for any other questions on the topic please Use Your Owners Manual.. I'm done trying to help you people... what a bunch of clueless thankless idiots... This site need's ASE mechanics here to help people that need and want the help.. Everytime I say something, people here ( I.E. Mr. Sheppard... Mr. Reynolds) try to to poke holes in my sugestions...So go on and drive your car until it starts knocking and quits.. then tell the world you did not cook your motor.. or better yet ground out a wire on your late model Cadillac and blow up a module or something expensive...
Best of luck to all of you people...
John P. Kechler, ASE Certified Mechanic
G'day John,
If you check their email addresses, they are one in the same.
Home grown Mechanic, amongst other things. :)
Since we got the question answered I can ask a question
Bruce, what is a Bowser?
grinch
Ladies and gentlemen, Elvis has left the building!
Peter Mason CLC #24665
Charlotte, NC
1968 Deville Convertible in progress
1989 Sedan DeVille
