1956 exhaust port installation
Started by M. Lipinski, July 07, 2009, 12:52:31 PM
M. Lipinski
Just purchased a pair of exhaust port assemblies from McVey's (very nice but pricey). I  understand how it all fits into the bumper ends, but not sure how the flange going towards the exhaust pipe is supposed to connect to the exhaust pipe.  The flange is square with a small hole at each corner.  Is it supposed to mate up to a similar flange on the exhaust pipe?  If anyone has any diagrams or pics or description I would appreciate it.  The service manual doesn't go into very much detail.  Thanks .  Mike
Otto Skorzeny
The exhaust pipes hang free in the bumper ends to allow for flexing, etc.
That flange originally had a flat piece of rubber/cloth stuff (like exhaust hangers are made of) with a hole in it for the tailpipe to slide through and sort of hang there.
I have a set of those from MCvey's that I bought in 2002. I used a section of radiator hose that fit over my tailpipe and slipped into the exhaust port. It works just fine and functions the same way the other does but is easier to install. It's not visible so unless you're showing the vehicle for points judging, I wouldn't worry about it.
Be sure to use all stainless steel nuts, washers and bolts to hold all the bezels, etc. together. Don't just go to Home Depot, go to a regular hardware store and buy the best ones they have.Brass would work, too.
I coated the inside of my "s" pipe with a rust proofing agent but I don't really think that's necessary. They are good quality pieces.
Look for another thread on this subject with the search function. I posted a diagram. If I can find it on my computer, I'll email it to you.
fward
HUGE VENDOR LIST CLICK HERE
J. Gomez
Mike,
In addition to Otto's comments, attached is the exhaust section from the part manual, although this shows the '54 & '55 models, 1956 uses the same technique. Pipes are inserted through the rubber insulator.
Hope this helps..!
J. Gomez
CLC #23082
M. Lipinski
Thanks to both of you for the excellent info (both the sketch and diagram help a lot).  I will get going on the installation.  Cadillac sure had a simple solution, didn't they?
