Under Hood Color
Started by Jack McClow CLC #15840, July 23, 2009, 05:00:43 PM
What is the correct color for the underside of the hood for a '53 Cadillac?  Flat black (or whatever shade of black it should be) or body color?   Would this be the same for other GM products of 1953 as well do you suppose?
Thanks.
Barry M Wheeler #2189
Jack, '41 was satin black, and it is probable that it was the same until they went to pads. Perhaps someone else can pin it down further.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Walter Youshock
Probably chassis black.  Definitely not body color.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
P W Allen CLC# 20193
#3
Jack, The entire underside should be a satin black (very little gloss), including the hinges and mounting brackets. A vinyl covered hood pad with a jute backing is then glued on and is correct for a 53. I did a lot of research on this subject during the restoration. This is what it should look like.
Paul
Paul
53 Coupe
Twin Turbine
Thanks, everybody, for the info ........ it is very helpful.
And thanks for the picture, Paul ........ that is very useful, too.  And that is a very beautiful '53 CDV you have there.
Jack.
Ted in Olympia WA
Just to add to this Eldorados up through 1978 were all satin black also.  Don't know about later than this.
TED
Mike Josephic CLC #3877
It's not correct that all Eldorados up until 1978 were satin black.
I have an ORIGINAL 1973 and the inner fender wells were most definitely GLOSS black
as well as the radiator support, etc.  I don't know when the change-over from satin to
gloss occurred prior to this.
As far as the 50's Eldorado's, the '55 inner fenders were BODY COLOR as well as the '56
and I believe the '54 as well.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Walter Youshock
And '57.  '58 went to black inner fenders.
Was your '73 built at Clark or Linden?  Wonder if that would make a difference in the gloss/satin?
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Otto Skorzeny
I thought they were all built at Clark?
fward
HUGE VENDOR LIST CLICK HERE
Ted in Olympia WA
Okay maybe I should have just said black, also I was talking more about under hood color and I don't think this is very gloss.  But you are right the inner fender are gloss.  But everything under the hood is black (of some finish) for up through 78 Eldorados.
Thanks for the correction.
TED
Walter Youshock
By '73, I think Linden was already opened.  Southgate started in the late '70's.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
