G'day Marcia,
When bleeding brakes, always start with the brake that is the furthest away from the Master Cylinder.
But, when no fluid is coming out, you need to check that the circuit isn't blocked along the way.
Seeing as you had frozen rears, it could well be that you have a problem in the rear line so I would be "cracking" the fittings starting at the rear, and attempt to bleed the brakes, working forward until you have fluid coming out the joints.
This will show you which part is blocked, and needs repairing.
Bruce.
