All Cads
Author Topic: 1994 Fleetwood Radio  (Read 1380 times)
Offline Dan Marinola
  • CLC# 4140
  • CLC Number: 4140
  • Name: Daniel P. Marinola
« on: August 06, 2009, 07:49:02 AM »
I have a 94 Fleetwood with a radio problem. Does anyone know if I purchase a head end radio ( the part in the dash) if I need to have the ECM scan it for it's serial number to allow it to play? Is there some kind of antitheft system on these radios? Any help greatly appreciated. Thanks,Dan.
Daniel P. Marinola
Offline Walter Youshock
Re: 1994 Fleetwood Radio
« Reply #1 on: August 06, 2009, 09:26:29 AM »
The part in the dash is just a control head.  The actual "radio" and amplifier is buried somewhere inside your dashboard.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
  • CLC# 4140
  • CLC Number: 4140
« Reply #2 on: August 06, 2009, 09:55:56 AM »
Thanks for the reply Walter but I think the rest of the "radio"is in the trunk mounted close to the antenna. The question is do I have to reacquaint the head end radio in the dash with the ECM of the car to make it play. Something about antitheft of radio components from the factory. Thanks,Dan
Daniel P. Marinola
« Reply #3 on: August 06, 2009, 10:02:41 AM »
Right you are--it IS in the trunk!  That was a smart move that came way too late.
Anyway, you shouldn't have to do anything to "reacquaint" the radio.  Just plug it in.
Is there anything in your Owner's MAnual regarding a Theftlok feature on the radio?  I thought that came later, like 1996.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
jeff1956
  • Guest
« Reply #4 on: August 06, 2009, 03:34:46 PM »
some gm radios require a scan tool be plugged in and the vin programmed in order to work....requires you show a receipt of purchase for the replacement radio as they likely will not reprogram for fear of it being stolen.
Offline okccadman
  • CLC Number: 5374
  • Name: Jim Jordan
« Reply #5 on: August 06, 2009, 06:57:05 PM »
I worked at a dealership in 1994 and swapped many of these units into and out of sold cars for customers.  You can just plug it in and go.  No computer coordination is necessary at all.  The only trick is not losing any of the tiny clips that hold the upper woodgrain moulding on!
Jim Jordan CLC# 5374
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
56 Fleetwood 75 Derham Limo
59 Fleetwood Sixty Special
66 Fleetwood Brougham
66 Superior Hearse/Ambulance
67 Fleetwood Sixty Special
68 Fleetwood Eldorado
76 Coupe de Ville d'Elegance
90 Brougham
92 Fleetwood Coupe
93 Allante
94 Fleetwood Brougham
02 Eldorado Commemorative Edition
