69 Cad A/C plenum blockage - mouse nest
Started by Dyson, August 19, 2009, 06:26:56 PM
Dyson
Anyone have experience with dissassembly to locate mouse nest in air passages?
All air seems blocked, so no air flow.  Compressor OK, air control lever [off-vent-A/C- Def...] operates, fan works [blower already removed and area cleaned once - no improvement].
Thoughts?
Dyson [longtime member Cad LaSalle Club - first time here]
'41-61, '69 CDV
Glen
Be sure you have vacuum to the purge door actuator.  Without vacuum to that actuator the air blows into the engine compartment.
Glen
Glen Houlton CLC #727
CLCMRC benefactor #104
Dyson
Could you mention the location, appearance or other details of that device?
Many Thanks
Dyson
Glen
Looking at the book, it looks like the purge door is at the left (driver’s side) end of the plenum in the engine compartment.  That puts it behind the engine.  With the door open the hot air in the plenum is blown out to the engine compartment.  I would think you could feel the air coming out under the plenum.
See the picture below.
Glen
Dyson
Glen - sincere thanks to you for the note and diagram.  I shall investigate ASAP -  a few days, as i am away..
Much appreciation.
Dyson.
Dyson
My mechanic friend finally got a look at the car.  He took out the blower motor and used a long flex wand which encountered a mouse nest of wadded fibers the size of a grapefruit-cantaloupe.  It came out in one piece.
Another outfit had removed the blower motor and vacuumed - to no avail.
I now have circulation and all seems well.
Thanks again to those who assisted.
Dyson
