Now I am really need help from You!
Started by Cadillac1955, August 25, 2009, 09:45:55 AM
Cadillac1955
Cadillac Eldorado transmission cooler 1955: Can someone tell me where those heat hoses go from the transmission cooler... I know one of them goes to the waterpump... but the other heat hose goes where??
Andrè Aga
Cadillac Coupe de Ville 1955
Cadillac Coupe de Ville 1964 "The Apollo"
Cadillac Conv. 1965
Walter Youshock
They should both branch off the water pump.  One is the feed line and the other is the return, like going to the heater core.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
I'm not so sure. On the '56 models, the other end of the hose is going in the middle of the engine block, passenger side, above the starter motor. I believe that '55 is identical.
Roger
Cadillac1955
Quote from: Roger Zimmermann #21015 on August 25, 2009, 11:09:10 AM
Roger
Hi Roger,
May I ask if You have a pic of the place the hose ends i the engine block??
Andrè Aga
Cadillac Conv. 1965
Walter Youshock
Sorry I jumped the gun--I have a '57 and all the hoses come off the water pump.  On my car, the trans cooler hoses are routed right under the intake manifold--a GREAT place to keep them nice and hot!
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Quote from: Cadillac1955 on August 25, 2009, 11:25:34 AM
Sorry, no picture and my cars are too far away. I had a look at the pictures I did from my cars, but this specific outlet is not visible. You have to search for yourself. If the exhaust manifold is installed, ou will not see the tube. You have to go under the engine; the tube is maybe 1" lenght.
Roger
Roger
Quote from: Walter Youshock on August 25, 2009, 11:43:35 AM
Yes, it's the same on the '57 Brougham, according to the pictures I have...
Roger
Carl Schreiber
Walter -
Kinda makes you think it might actually be a transmission HEATER, to maintain proper operating temperature...
Carl Schreiber
