Rubber vendor
Started by J I Garner, September 06, 2009, 12:53:57 PM
J I Garner
I am in need of all the rubber for my 1962 Eldorado. It is time to start the finishing process. Who is the best recommended vendor?
Jim
carguyblack
I'd give Alvin Arnold from Paragould, Arkansas a call. 870-236-7253.  He's a Steele dealer and tries to give folks the best deal he can. I think he sources out comparable parts made by less expensive manufacturers as well and passes that on to you. Hope this helps. Chuck
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
Kevin Kenneally
Rubber The Right Way..  866-789-7879..  I have used them and they are great!
jeff1956
I'll second about alvin arnold...he's a great guy and is in my town.  However, when I talked to him friday he will be on vacation tomorrow(monday) through early october....he takes a month vacation every year so if you're not in a hurry he should be back by early october.  Just letting you know in case you happen to call and can't get ahold of him.
Otto Skorzeny
You can't go wrong with Steele either. Basically a one stop shop for everything you will need inside and out.
http://steelerubber.com/
fward
HUGE VENDOR LIST CLICK HERE
JIGarner
Thank you all for the advice. I'll Check with both sources
Jim
