59 turn signal switch steering column assembly
Started by Christian Claeys, September 07, 2009, 01:30:29 AM
Christian Claeys
I have been carefully documenting and photographing everything on my '59 Sedan DeVille as I disassemble each part of my body off restoration.  All has gone smoothly until.....I was removing the turn signal switch plate on the underside of the steering column while breaking down the components to prepare for paint.  When I removed the two screws from the cresent shaped contact plate that the wires are soldered to, tiny ball bearings and copper electrical contact pieces fell in my lap.  Does anyone have a diagram showing how this component is assembled?
Vsixteen
Hi
Did you also get two tiny springs out of it? I just did mine and I can tell you how to put it back together. Do you have a photo of all your parts?
1958 Coupe De Ville
1958 Sedan De Ville
1958 Convertible
1959 Convertible CLC Senior & AACA Senior
Christian Claeys
I can take a photo tomorrow and put it up, I hope I have all the parts  :-\
